Discovery 的强大功能是每位工程师的必需装备
ANSYS Discovery Live 提供即时 3-D 仿真,与直接几何结构建模紧密关联,能够实现交互设计探索和快速产品创新。通过这种交互式体验,您可以处理几何结构、材料类型或物理输入,并即时查看性能变化。
利用 Discovery Live 在更短的时间内测试更多设计迭代、执行有关新概念的可行性研究并更快地将产品投入市场。
ANSYS Discovery Live 能够无缝对接产品的 3-D 设计系列并与 ANSYS Discovery SpaceClaim 和 ANSYS Discovery AIM 相互补充。
ANSYS Discovery Live Ultimate 2019 R1 | 4.7 Gb
The Ansys product team is pleased to announce the availability of Ansys Discovery Live 2019 R1, is the first ever simulation environment that provides real-time answers to engineering challenges. It lets you interactively change geometry, physics inputs, and results display all while instantly visualizing design performance.
About ANSYS Discovery Live. The instant, interactive simulation environment of ANSYS Discovery Live allows engineers — at all levels and in every discipline — to explore their concepts and designs. Dramatically easier to use than other simulation tools, Discovery Live performs simulation in near real-time.
- Interactive Geometry
Engineers no longer need to wait for geometry modification, re-meshing and resolving. Discovery Live begins re-computing results immediately, without a need to start over.
- Interactive Physics
Gain immediate insight when a load is suddenly increased, a material is changed or an input velocity drops to zero. Set up multiple physics on the same model and eliminate unnecessary geometry preparation.
- Interactive Results
As quickly as you generate questions, Discovery Live has answers ready for viewing. In a fluids application, for example, no other engineering simulation tool allows you to adjust the location, rate and size of a particle stream in one instant, then immediately switch to a composite view and see maximum pressures throughout the model.
About ANSYS Inc. Founded in 1970, ANSYS employs nearly 3,000 professionals, many of whom are expert M.S. and Ph.D.-level engineers in finite element analysis, computational fluid dynamics, electronics, semiconductors, embedded software and design optimization. Our exceptional staff is passionate about pushing the limits of world-class simulation technology so our customers can turn their design concepts into successful, innovative products faster and at lower cost. As a measure of our success in attaining these goals, ANSYS has been recognized as one of the world's most innovative companies by prestigious publications such as Bloomberg Businessweek and FORTUNE magazines.
