计算完报错1、stretching solution didn't coverge in 100 iterations allowed.Either the tool data is not clean ,excessive cracks or excessive wrinkles occur or too large time steps are used.The current geometry will be written to the end of the post file.This geometry...
2、Node 406's position on sheet surface after systim solution was not found.Either the tool data is not clean,excessive cracks or excessive wrinkles occur or too large time steps are used.The current geometry will be written to the end of the post file...
3、Unable to find position of 2 nodes on sheet surface.Either the tool data is not clean,excessive cracks or excessive wrinkles occur or too large time steps are used.The current geometry will be written to the end of the post file.This geometry is the... |
