Closes Before Bottom
Specify the desired distance you want the cam (and tools) to be closed before other tools such as pads or forming tools. This is very useful when simulating dwell cams or filler cams. Setting a distance from bottom for the dwell side will ensure it is closed before the forming cam engages the sheet.
想问下这里的这个dwell cams 和 filler cams分别是什么CAM??? |
